Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: '96 VR6 - Auto to Manual [Build]
  1. #31
    Nov 2014
    Had to have a break, but I've kept busy ordering parts (how could I resist) and doing small things.
    I've been rewrapping all the loom behind the dash, it was covered in degrading tape and deteriorating foam.
    New parts coming in:
    - Water pipe kit, I figured if I'm going this far I may as well do as much preventative maintenance.
    - Shifter Mounting Bracket Bushing Kit
    - Water Pump
    - Cabin Filter
    - Torque Wrench (Once I'm reassembling I'll need to be able to tighten everything back to the right measurements!)
  2. #32
    Nov 2014
    I've been trying to get some good hours in, but I can't seem to separate the automatic transmission from the engine. I've removed every bolt that I can see, and it still won't separate.
    Going to have a read around vortex etc. and try and see what I'm missing.
    I removed the CV joints from the transmission, but the axles won't come out of the hub. I've tried some penetrative spray and a rubber mallet, but neither would move.
    Does anyone have the VW tool or something similar for removing axles?
  3. #33
    Nov 2014
    Pulled out the auto transmission! The thing is huge, and insanely tight to manoeuvre in the engine bay.
    I missed the torque converter bolts when removing the transmission, which left even less space to move things around. I ended up rotating the whole transmission by 90* degrees clockwise using and engine crane + jacks/jack stands, which allowed it to slide straight off! Definitely the easiest way to drop the transmission, especially if you're doing it solo.
    Torque Converter still attached to the engine:
    (picture taken from left wheel well)
    And here is the car resting in the garage:
  4. #34
    Nov 2014
    Today I painted the interior pillars from grey to black. They are all relatively easy to get off. I scrubbed them all with warm soapy water beforehand to remove anything on the surface and then towel dried them off as well as let them stand outside for a while.
    I took a piece of some stock black interior paneling and compared it to a few different paints in Autobarn, I ended up going with the one above. (Motortech Matt Black)
    The painting took a while, since I was doing light coats and quite a few pieces. The good news is though, the colour is indistinguishable from the factory black! I'll upload some photos in a few days when I can get some snaps in the sun.
    I'm going to give them a while to cure, and then I'll give the paint a bit of a scratch and rub to see how well they will hold up.
  5. #35
    Nov 2014
    Just received some mail to tie me over during the week!
    Got these JOM blue coilovers for a steal off eBay. Brand New, shipped from Germany for $399.
  6. #36
    Jun 2011
    Good luck.
    Depending on how you run them. I suggest you get the rear springs reset a few inches lower. They are too soft when lowish
  7. #37
    Nov 2014
    I'm content with them not being slammed. I'll keep it in mind when putting them in, thanks!
  8. #38
    Nov 2014
    My impact gun stripped one of these bolts and the rest are pretty soft too. (not my picture, mine's a drive plate, not a fly wheel).
    Pretty frustrated, not looking forward to trying to get these out. Not sure how I'll do it. Heat it up a bit, use a chisel to try and bite into the bolt and chip it loose?
    Ugh.
  9. #39
    Jun 2011
    Ouch. ...
    Vice grips
  10. #40
    May 2014
    Newcastle, Australia
    Grind the head off, once there is no pressure on the threads it will thread out easy. The are insanely tight so I doubt anything would get them loose while still under pressure.
